NZHondas.com Mobile Apps! | Remember to search Google Play and the Apple App Store for NZHondas to access the site when you're on the move.
View RSS Feed
eg6 sir
Bens eg4 ground up build
Rate this Entry
by , 11th February 2012 at 03:49 PM (190 Views)
decided i wanted a dedicated project car instead of using my daily after reading this thread on k20a.org [url]http://www.k20a.org/forum/showthread.php?t=22374[/url] so had a hunt around and managed to score this nz new eg4 off hayce for a steal of a price just after new years
[IMG]http://nzhondas.com/members/eg6+sir-albums-1937-picture24639-img-0058.jpg[/IMG]
[IMG]http://nzhondas.com/members/eg6+sir-albums-1937-picture24642-img-0061.jpg[/IMG]
after i got back from a holiday at the beach the teardown started
[IMG]http://nzhondas.com/members/eg6+sir-albums-1937-picture25150-build-pics-002.jpg[/IMG]
[IMG]http://nzhondas.com/members/eg6+sir-albums-1937-picture25151-build-pics-001.jpg[/IMG]
after pulling some panels off i noticed that the front drivers side has been repaired at some stage so got to work removing all the paint down to bare metal to assess the damage and found a lot of bog but underneath it all it was fairly straight apears to have been beaten into shape with a hammer or something
[IMG]http://nzhondas.com/members/eg6+sir-albums-1937-picture25149-build-pics-003.jpg[/IMG]
[IMG]http://nzhondas.com/members/eg6+sir-albums-1937-picture25143-build-pics-009.jpg[/IMG]
also were the drivers door bolts on had been repaired at somestage as there was a pile of bog there and on the lower rear guard once again when i removed all the bog(about 6mm thick) i was suprised again to see that it mas mostly straight and now lined up with the door and side skirt
[IMG]http://nzhondas.com/members/eg6+sir-albums-1937-picture25144-build-pics-008.jpg[/IMG]
gutted the interior completly and removed sound deadening, as i didnt know were to get dry ice i just used a hammer and chisel to slowly chip away at it, took a couple of weeks with long breaks in between then cleaned it up with a drill and wirebrush
[IMG]http://nzhondas.com/members/eg6+sir-albums-1937-picture25142-build-pics-010.jpg[/IMG]
[IMG]http://nzhondas.com/members/eg6+sir-albums-1937-picture25147-build-pics-005.jpg[/IMG]
also when i was bord i decided to convert the steering rack properly to manual removing the internal piston. now just have to get the line fittings machined off.
painted the subframe and suspension arms while they were out aswell to freshen them up as i want this car to look brand new once finished
[IMG]http://nzhondas.com/members/eg6+sir-albums-1937-picture25148-build-pics-004.jpg[/IMG]the last few day i have been cleaning under the chassis for repainting using a scrubing brush, will update on progress soon. hope you all enjoy all comments welcome
Categories
Builds
Comments
  1. Detract's Avatar
    Looks about as stripped as mine.
    What's your plans for it?
  2. eg6 sir's Avatar
    planing to do a b18c block b16a head with mild port and high compression and half cage built to the specs of a full cage so i can add to it properly later on when i get a race licence and just a nice clean body, everything kept to the bare minimum
  3. silver2k's Avatar
    Wow - you started after me 0- and you're already so far head! Good work man!
